Voci con l'etichetta :
Chiudi
Chiudi
Change spreadsheet settings
You can change layout settings for the spreadsheet, i.e. the page orientation, size, margins, as well as specify which interface elements you want to be hidden or shown.
To access the current spreadsheet settings,
  2. tap the arrow next to the Spreadsheet Settings Spreadsheet Settings menu item.
Currently, the following spreadsheet settings are available:
  • Color Scheme - is used to select the necessary Color Scheme. It allows to change the default color palette for worksheet elements (font, background, autoshapes and charts).
Chiudi
