You can selectively clear the cell from some property or formatting:
- select a cell, a range of cells or the whole worksheet,
- open the Clear settings panel by
- tapping the
icon at the top toolbar, or
- tapping the
option in the pop-up menu and choosing the Clear menu item,
- choose one of the available clearing types:
- All - to completely clear a cell from text, formatting, formulas, etc,
- Text - to clear a cell from text and formulas,
- Format - to remove all formatting applied to the cell,
- Comments - to remove all comments,
- Hyperlinks - to remove all hyperlinks. Both external and internal links will be removed,
- return to the previous screen by tapping the
arrow on the left and сlose the cell settings panel by tapping the
icon on the right.
