Search for certain text
- tap the
Tools icon in the right corner of the top toolbar,
- tap the
Find and Replace option to activate the Find panel,
![Search panel](/it/images/Help/Mobile/Documents/Android/Presentations/search_panel.png)
- if necessary, you can specify search parameters by tapping the
Search Options icon on the left.
The Find and Replace settings panel opens. Turn on the necessary switchers:
![Search options panel](/it/images/Help/Mobile/Documents/Android/Presentations/search_options_panel.png)
- Case sensitive - is used to find only the occurrences typed in the same case as your inquiry (e.g. if your inquiry is 'Editor' and this option is selected, such words as 'editor' or 'EDITOR' etc. will not be found).
When ready, tap Done.
- enter your inquiry into the data entry field,
![Search panel](/it/images/Help/Mobile/Documents/Android/Presentations/search_panel_with_text.png)
- use arrow buttons to navigate through the found occurrences towards the beginning of the presentation (if you tap the
icon) or towards the end of the presentation (if you tap the
icon) from the current position.
To clear your inquiry, use the
icon to the right of the entry field.
Replace the found matches
- tap the
Search Options icon on the left to open the Find and Replace settings panel,
- tap the Find and Replace menu item, change the search parameters, if necessary, and tap Done. The Find panel will change:
![Find and Replace panel](/it/images/Help/Mobile/Documents/Android/Presentations/search_replace_panel.png)
- enter the replacement text into the second data entry field,
- use arrow buttons to navigate through the found occurrences and tap Replace to replace the currently selected occurrence,
- to replace all the found occurrences, hold the Replace caption next to the entry field until the menu with the Replace All option appears, then tap it.
Exit the Find mode
To close the Find panel, tap within the presentation area.
