Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Insert images
Add an image
  1. select the slide where you want the image to be put,
  3. switch to the Picture from Library local Image tab,
  4. select the Picture from library option to open the Media Library where you can select the necessary file.
    You must have appropriate permissions on your device Media Library.
The image will be added. Now you can change its properties and position.
Adjust the shape of the image and its border
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
  1. select the image by tapping it,
  2. open the settings panel by
  3. tap the necessary menu item: Style, Replace, Reorder, or Align. Use the Return arrow on the left to return to the previous settings section.
    The Style section contains Border style settings and allows to add borders to an image:
    • Size - to set the necessary width of the border;
    • Color - to select the necessary border color on the Theme colors or Standard colors palette or create your own Custom color.
    Chart border style local
    The Replace section allows to replace the current image shape with another one selected from the menu. The shape of the image will change correspondingly.
    Reshape image
    The Reorder section allows to set the selected image position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
    The Align section allows to align the image on the slide. To learn more, please refer to the Manipulate objects section of this guide.
  4. close the shape settings panel by tapping the Close settings panel arrow on the right or use the Return icon on the left to return to the previous settings section.
Remove the image
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete icon local option in the pop-up menu, or
  • open the shape/image settings panel by tapping the Edit object icon at the top toolbar. You can use the REMOVE SHAPE button at the Shape tab.
Chiudi
