Chiudi Centro assistenza ONLYOFFICE Documents for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Strumenti e impostazioni Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Add hyperlinks formattare caratteri Applicare stili di decorazione dei caratteri Applicare stili di formattazione Formattazione dei messaggi Come creare la base di conoscenza? Inserire un capolettera Insert text objects Insert text objects Inserire e formattare testo More articles Posta Impostare il tipo, la dimensione e il colore del carattere Impostare tipo di carattere, dimensione, stile e colore Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks inserire collegamenti Aggiungere collegamenti ipertestuali Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Formattazione dei messaggi Come creare la base di conoscenza? Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks collegamenti esterni Aggiungere collegamenti ipertestuali Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks collegamenti interni Aggiungere collegamento ipertestuale Aggiungere collegamento ipertestuale Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add a hyperlink select the text passage that will get clickable and do the following: tap the icon at the top toolbar to open the new object insertion panel, switch to the Link tab, specify the hyperlink parameters: Link - enter a URL in the format http://www.example.com in the Link field below. Display - enter a text that will get clickable and lead to the address specified in the upper field. Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to. tap the INSERT button. Note: to follow the added link, double-tap it, choose the Open Link option in the pop-up menu. Edit or remove the added hyperlink double-tap the link and open the settings panel in one of the following ways: tap the icon at the top toolbar, or tap the option in the pop-up menu. switch to the HYPERLINK tab and perform the actions you need: edit your data and tap the EDIT LINK button to save the changes. use the REMOVE LINK button to delete the added hyperlink. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
