Chiudi Centro assistenza User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Personal ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs All Editors Document Editor Spreadsheet Editor Presentation Editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors User Guides Watch video ONLYOFFICE Documents for Android Document Editor overview ONLYOFFICE Documents for Android Spreadsheet Editor overview ONLYOFFICE Documents for Android Presentation Editor overview How to open and save docs to different formats using ONLYOFFICE Documents for Android How to share files using ONLYOFFICE Documents for Android How to connect ONLYOFFICE Documents for Android to Cloud How to connect ONLYOFFICE Documents for Android to Cloud How to connect ONLYOFFICE Documents for Android to Personal How to connect ONLYOFFICE Documents for Android to Server How to edit documents stored on Nextcloud with ONLYOFFICE on your Android device Edit Word docs on your iPad with ONLYOFFICE app ONLYOFFICE mobile apps Mostra sommario Nascondi sommario ONLYOFFICE provides mobile solutions to access your files and edit them from an iOS or Android device. The solutions include ONLYOFFICE Documents for iOS and Android, ONLYOFFICE Project for iOS and Android, and ONLYOFFICE web editors that are adapted for working with documents in the mobile device web browser both on iOS and Android. ONLYOFFICE Documents app for iOS Documents app for iOS changelog Getting Started Overview Common operations for iOS Manage files Open or create new files and folders Share files and folders Document Editor for iOS Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Handwriting recognition Formattazione della pagina Impostare parametri di pagina Inserire interruzione di pagina Inserire interruzioni di sezione Inserire numeri di pagina Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Insert line breaks Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Fillable forms Filling out a form Strumenti e impostazioni Visualizzare informazioni sul documento Change application settings Use the Find and Replace function Save, export, print your document Protect documents with a password Spreadsheet Editor for iOS Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create/delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Apply table styles Modifica delle righe/colonne Manage data in rows/columns Add or remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Visualizzare informazioni sul file Change application settings Use the Find and Replace function Set language and region Save, export, print your spreadsheet Protect spreadsheets with a password Presentation Editor for iOS Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Create charts Manipulate objects Strumenti e impostazioni Visualizzare informazioni sulla presentazione Use the Find function Save and export your presentation Change application settings Print your presentation Protect presentations with a password ONLYOFFICE Documents app for Android Documents app for Android changelog Getting Started Overview Common operations for Android Manage files Open or create new files and folders Share files and folders Document Editor for Android Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Insert endnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Modifica collaborativa dei documenti Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document Visualizzare informazioni sul documento Spreadsheet Editor for Android Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet Visualizzare informazioni sul file Presentation Editor for Android Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione ONLYOFFICE Projects for iOS Overview Common operations Project management Tasks ONLYOFFICE Projects for Android Overview Changelog Common operations Project management Tasks Discussions Project documents ONLYOFFICE Mobile web editors for iOS Getting Started Overview Common operations for iOS Manage files Open or create new files and folders Share files and folders Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzione di pagina Insert column breaks Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Filling out a form Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Create a Table of Contents Strumenti e impostazioni Modifica collaborativa dei documenti Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document Visualizzare informazioni sul documento Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create/delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Add or remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Use the Find and Replace function Change spreadsheet settings Change application settings Macros settings Download and print your spreadsheet Visualizzare informazioni sul file Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione ONLYOFFICE Mobile web editors for Android Getting Started Overview Common operations for Android Manage files Open or create new files and folders Share files and folders Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzione di pagina Insert column breaks Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Create a Table of Contents Strumenti e impostazioni Modifica collaborativa dei documenti Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document Visualizzare informazioni sul documento Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create/delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Use the Find and Replace function Change spreadsheet settings Change application settings Macros settings Download and print your spreadsheet Visualizzare informazioni sul file Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors
