You can change a slide size for all the slides in the presentation, as well as specify which color scheme you want to use.
To access the current presentation settings,
- tap the
Settings icon in the right corner of the top toolbar,
- tap the arrow next to the
Presentation settings menu item.
Currently, the following presentation settings are available:
- Slide size - is used to change the current Slide size. The default slide size is Widescreen (16:9) that can be switched to Standart (4:3).
- Color schemes - is used to select the necessary Color scheme. It allows to change the default color palette for slide elements (font, background, autoshapes and charts).
