Chiudi Centro assistenza ONLYOFFICE Documents for Android Document Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Undo/redo your actions operazioni di modifica di base Annullare/ripristinare azioni Controllo ortografia Copiare/incollare testo, annullare/ripristinare azioni Copiare/incollare testo, annullare/ripristinare azioni Tagliare/copiare/incollare dati Tasti di scelta rapida Tasti di scelta rapida Tasti di scelta rapida Spell-checking More articles Spell checking Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Manage files Open or create new files and folders Share files and folders Navigate through your document Select, cut, copy, paste text Undo/redo your actions Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions annulla e ripristina Copiare/incollare testo, annullare/ripristinare azioni Copiare/incollare testo, annullare/ripristinare azioni Annullare/ripristinare azioni Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions More articles Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions Undo/redo your actions To perform the undo/redo operations, use the corresponding icons at the top toolbar: tap the Undo icon at the top toolbar to undo the last operation you performed. tap the Redo icon at the top toolbar to redo the last undone operation. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
