Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Download your presentation
Download the presentation
To download the current presentation, opened in the Clouds section, to your device,
  2. tap the Download Download menu item,
  3. tap one of the available file formats: PPTX, PDF, PDF/A, ODP, POTX, OTP.
The file will be downloaded and stored on your device.
Export the presentation
To export a presentation to your device, you should locally open the file by tapping on it in the On Device section and follow these steps:
  2. tap the Print Export menu item,
  3. tap one of the available file formats: PPTX, PDF, ODP,
  4. specify the path where the file will be saved. It can be either the same device or a cloud storage.
Chiudi
