Voci con l'etichetta :
Chiudi
Chiudi
Select, cut, copy, paste text and objects
Set the insertion point
To position the cursor, touch a text line within the text box.
Pop-up menu
The menu options allow you to:
  • Paste icon Paste previously copied text,
  • Delete the next character within the line of text,
  • Edit text (i.e. open the text/paragraph settings panel),
  • if you select the More option, a submenu opens that allows to Add link or Add Comment.
Select text and objects
Selection handles
To select an object (shape, image, or chart), tap it. To select a text box, tap its border.
When you select an object, the pop-up menu appears that contains the following options: Cut, Copy, Paste, Delete, Edit (i.e. open the object settings panel). When you select a text passage, the More option is also available. If you select the More option, a submenu opens that allows to perform the following action: Add link (this option is only available for the selected text), Add Comment to leave comments, or View Comment to view the current comment.
Double-tap a slide in the slide list to open the pop-up menu that contains the following two options: Paste and Edit. The Edit option allows to open the slide settings panel.
Cut, copy, paste text and objects
To cut, copy and paste text passages/objects within the current presentation use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
  • Cut icon Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same presentation.
  • Copy icon Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same presentation.
  • Paste icon Paste – put the cursor within a text box where you want to paste the previously copied text fragment or double-tap the slide where you want to paste the previously copied object and use the Paste option from the pop-up menu. The text will be inserted at the current cursor position. The object will be inserted onto the currently selected slide. The data can be previously copied from the same presentation.
Chiudi
