To customize your presentation, you can select a theme for the entire presentation. Themes allow you to quickly change the presentation design, notably the slides background appearance, predefined fonts for titles and texts and the color scheme that is used for the presentation elements.
To select a theme for the presentation,
- in the slide list on the left, select any slide,
- open the slide settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- tap the Theme menu item,
- tap the necessary theme in the themes gallery (swipe up to see more themes),
![Themes gallery](/it/images/Help/Mobile/Documents/Android/Presentations/themes.png)
- close the slide settings panel by tapping the
arrow on the right.
The selected theme will be applied to all the slides.
