To customize your presentation, you can change the background fill for each separate slide. To change a background fill:
- in the slide list on the left, tap the slide you want to apply the fill to,
- open the slide settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- tap the Style menu item,
- select the necessary color on the Theme Colors or Standard Colors palette or create your own Custom Color (swipe it up to see more colors),
- go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
- tap the
button to apply the color to the selected autoshape.
To clear the slide background color, use the
No Fill icon on the Standard Colors palette.
- close the slide settings panel by tapping the
arrow on the right.
