Chiudi Centro assistenza ONLYOFFICE Mobile web editors for Android Document Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS ONLYOFFICE Mobile web editors for Android Overview Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Insert page numbers formattazione pagina Inserire intestazioni e piè di pagina Inserire numeri di pagina Inserire interruzioni di sezione Inserire interruzione di pagina Impostare parametri di pagina Visualizzare/nascondere caratteri non stampabili Aggiungere segnalibri Aggiungere una filigrana More articles Insert date and time Set page parameters Insert page breaks Insert section breaks Insert page numbers Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Adding page numbers in word intestazioni e piè di pagina Inserire intestazioni e piè di pagina Insert footers Insert headers and footers Insert date and time Inserire numeri di pagina Insert page numbers Insert page numbers Insert page numbers More articles Insert page numbers Adding page numbers in word numerazione pagine Inserire numeri di pagina Insert page numbers Insert page numbers Insert page numbers Insert page numbers Adding page numbers in word tap the icon at the top toolbar to open the new object insertion panel, switch to the Other tab, select the Page Number option, specify the page number position on the page: Left Top, Center Top, Right Top, Left Bottom, Center Bottom, Right Bottom, Current Position. Set up additional numbering parameters using the header settings panel: double tap the header where the page number is located, open the text, paragraph and header settings panel by tapping the icon at the top toolbar, or tapping the Edit option in the pop-up menu, open the HEADER tab and set necessary parameters: Turn on the Different first page switcher to apply a different page number to the very first page or in case you don't want to add any number to it at all. Turn on the Different odd and even pages switcher to insert different page numbers for odd and even pages. The Link to Previous option is available in case you've previously added sections into your document. If not, it will be grayed out. Moreover, this option is also unavailable for the very first section (i.e. when a header or footer that belongs to the first section is selected). By default, this box is checked, so that unified numbering is applied to all the sections. If you select a header or footer area, you will see that the area is marked with the Same as Previous label. Turn off the Link to Previous switcher to use different page numbering for each section of the document. The Same as Previous label will no longer be displayed. The Page Numbering section allows to adjust page numbering options across different sections of the document. The Continue from previous section option is selected by default and allows to keep continuous page numbering after a section break. If you want to start page numbering with a specific number in the current section of the document, turn off the Continue from previous section switcher and specify the necessary starting value in the Start at field using the or arrows to decrease or increase the current value. close the header settings panel by tapping the arrow on the right. to switch to the document body, double tap within the working area. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
