Move sheets
To move an existing sheet, touch the sheet tab you wish to move and tap the More > Move option in the context menu. The Move before sheet menu will open. Specify in front of which sheet the selected sheet will be placed. Or tap the (Move to end) option to move the sheet to the very end of the book.
Rename sheets
To rename an existing sheet, tap the current sheet tab once so that the pop-up menu appears, then tap the Rename option. In the Sheet Name window that opens, enter the desired sheet name and tap OK.
Hide/Unhide sheets
If you have a lot of sheets, you can hide some of them you don't need for the moment to facilitate the work. To do that, tap the current sheet tab once to access the pop-up menu with the More -> Hide option, then tap it.
To display a hidden sheet, tap the current sheet tab once or double-tap an inactive tab so that the pop-up menu appears, then tap the More -> Show option, and select the sheet you want to unhide.
Duplicate sheets
To duplicate an existing sheet, tap the current sheet tab once to access the pop-up menu with the More -> Duplicate option, then tap it.
Change tab colors
To differentiate the sheets, you can assign different colors to the sheet tabs. To change the tab color, tap the current sheet tab once to access the pop-up menu with the More -> Tab color option, then tap it. In the Tab Color panel, select the necessary color on the Theme Colors or Standard Colors palette or create your own Custom color.
- go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
- tap the
button to apply the color to the selected autoshape.
To clear the tab color, use the
icon on the Standard Colors palette.
