Artikel zum Thema:
Schließen
Schließen
In der cloud testen
Selective cell clear
You can selectively clear the cell from some property or formatting:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Clear settings panel by
    • tapping the Edit icon local option in the pop-up menu and choosing the Clear menu item,
  3. choose one of the available clearing types:
    • All - to completely clear a cell from text, formatting, formulas, etc,
    • Text - to clear a cell from text and formulas,
    • Format - to remove all formatting applied to the cell,
    • Comments - to remove all comments,
    • Hyperlinks - to remove all hyperlinks. Both external and internal links will be removed,
    Selective clear
  4. return to the previous screen by tapping the Back arrow on the left and сlose the cell settings panel by tapping the Close settings panel icon on the right.
Herunterladen Bringen Sie Ihrem Roboter das Lesen bei Dokumente, Tabellenkalkulationen und Präsentationen
in allen gängigen Formaten anzeigen und bearbeiten
Schließen
