Schließen Hilfe-Center ONLYOFFICE Documents for Android Document Editor Document Editor vollständige Dokumentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Grundfunktionen Navigate through your document Select, cut, copy, paste text Undo/redo your actions Seitenparameter festlegen Set page parameters Insert section breaks Insert page numbers Absatzformatierung Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Textformatierung Set font type, size, and color Apply font decoration styles Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Grundfunktionen Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operationen mit Tabellenblätter Create or delete sheets Manage existing sheets Zellformatierung Set font type, size, and color Add hyperlinks Bearbeiten von Zelleigenschaften Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Bearbeiten von Zeilen und Spalten Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Objekte bearbeiten Insert images Insert formulas Insert autoshapes Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Grundfunktionen Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Folien bearbeiten Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Textformatierung Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossar Video Häufig gestellte Fragen Allgemeines Technologie Preise Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Add hyperlinks Textformatierung Dekoschriften anwenden Formatvorlagen anwenden Verzierung Ihrer Beiträge Wie erstellt man eine Wissensdatenbank? Initialbuchstaben einfügen Textobjekte einfügen Textobjekte einfügen Text einfügen und formatieren More articles E-Mail Schriftart, -größe und -farbe festlegen Bestimmen Sie die Schriftart, -größe, Farben und Stil Schriftart, -größe und -farbe einstellen Schriftdekorationsstile anwenden Hyperlinks einfügen Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Set font type, size, and color Apply font decoration styles Add hyperlinks Set font type, size, and color Add hyperlinks Set font type, size, color Apply font decoration styles Add hyperlinks Links einfügen Hyperlink einfügen Fügen Sie die Hyperlinks hinzu Hyperlink einfügen Verzierung Ihrer Beiträge Wie erstellt man eine Wissensdatenbank? Hyperlinks einfügen Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks externe Links Hyperlink einfügen Fügen Sie die Hyperlinks hinzu Hyperlink einfügen Hyperlinks einfügen Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks More articles Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add hyperlinks Add a hyperlink tap the icon at the top toolbar to open the new object insertion panel, switch to the Other tab, select the Link option, after that the Add Link screen will appear where you can specify the hyperlink parameters: Link - enter a URL in the format http://www.example.com. Display - enter a text that will get clickable and lead to the web address specified in the upper field. Note: if you've selected a text passage before tapping the icon, the Display field will be filled with the selected text fragment. Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to. tap the INSERT button. Note: to follow the added link, tap the Open Link option in the pop-up menu. Edit or remove the added hyperlink select the link and open the text and paragraph settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu, switch to the HYPERLINK tab and perform the actions you need: edit your data and tap the EDIT LINK button to save the changes. use the REMOVE LINK button to delete the added hyperlink. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Wer sich dafür interessiert hat, hat auch das Folgende gelesen: Schließen
