Control Panelv.2.9
ONLYOFFICE Control Panel changelog
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Stellen Sie sich vor, dass Sie Geschäftsführer eines kleinen oder mittelständischen Unternehmens sind und gerade ONLZOFFICE erhalten haben. Das erste, was Sie tun müssen, ist die Erstellung der Konten für alle Mitarbeiter. Aber wenn die Anzahl der Mitarbeiter mehr als 50 Personen ist, wird dieser Prozess viel Zeit in Anspruch nehmen.
Darum brauchen Sie sich nicht zu kümmern, weil ONLYOFFICE Ihnen die Option LDAP-Support bietet, die es Ihnen ermöglicht, die gewünschten Benutzer und Gruppen aus Active Directory in ONLYOFFICE in wenigen Minuten zu importieren. Die neu angelegten Benutzer müssen sich nicht mehr mehrere Kennwörter und Logins merken, weil sie sich in Portal mithilfe Ihrer Windows-Anmeldeinformationen anmelden werden.
Diese Option ist nur für die Server-Version verfügbar.
Lesen Sie diesen Artikel, um zu erfahren, wie Sie LDAP-Eistellungen ändern können!
Handlungsanweisung
- Gehen Sie zur Sektion Einstellungen. Dafür klicken Sie aufs Symbol
in der rechten oberen Ecke.
- Wechseln Sie in die Registerkarte LDAP-Einstellungen.
- Aktivieren Sie das Kontrollkästchen LDAP-Authentifizierung aktivieren und füllen Sie alle benötigten Felder aus:
Warnung
Bitte beachten Sie! Wenn Sie bereits einige Benutzer importiert haben und Einstellungen verändert haben (z.B. Server, Benutzerfilter, DN der Benutzer, Gruppenfilter, DN der Gruppen), werden vorhandene Benutzer und alle Daten,einschließlich Dokumente, E-Mails usw. gefiltert gemäß diesen Einstellungen, GELÖSCHT. Wir empfehlen Ihnen, ein Backup zu erstellen, bevor Einstellungen verändert werden.
- Geben Sie den DNS-Namen oder IP-Adresse des Servers ins Feld Server ein,
- Bestimmen Sie Portnummer. Standardmäßig wird sie auf 389 gesetzt, aber Sie können es ändern (z.B., Port für SSL-Verbindung ist 636),
- Geben Sie den absoluten Pfad zum Verzeichnis ins Feld DN der Benutzer ein,
- Füllen Sie das Feld Benutzerfilter, falls Sie die Suchkriterien bestimmen möchten,
Sie können die Syntaxbeispiele des Suchfilters
hier finden.
- Die Felder Attribut der Verknüpfung (ein Attribut, das wird genutzt, um die Benutzerobjekte von anderen Active Directory-Objekten zu unterscheiden) und Attribut des Logins (ein Attribut, das dem Active Directory-Login entspricht) sind standardmäßig eingestellt, aber Sie können sie nach Bedarf ändern.
- Aktivieren Sie das Kontrollkästchen Gruppenzugehörigkeit, wenn Sie die Gruppen vom LDAP-Server/Active Directory zu ONLYOFFICE hinzufügen möchten und füllen Sie alle benötigten Felder aus:
Warnung
- Aktivieren Sie das Kontrollkästchen Authentifizierung, falls Sie nicht über entsprechende Rechte zum Lesen der Daten vom LDAP-Server/Active Directory verfügen, und geben Sie die Anmeldeinformationen des Benutzers mit entsprechenden Rechten ein.
- Klicken Sie auf den Button Speichern.
- Im Fenster 'Hinzufügen von Benutzern' klicken Sie auf den Button Ja, Benutzer hinzufügen.
Der Importvorgang wird einige Zeit dauern, das hängt von der Anzahl der Benutzer, Gruppen, Computerspezifikationen usw. ab.
