Close Help Center ONLYOFFICE Documents for Android Document Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Basic operations Navigate through your document Select, cut, copy, paste text Undo/redo your actions Page formatting Set page parameters Insert section breaks Insert page numbers Paragraph formatting Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Text formatting Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operations on objects Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Tools and settings Collaborative document editing Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Basic operations Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operations with sheets Create or delete sheets Manage existing sheets Cell text formatting Set font type, size, and color Add hyperlinks Editing cell properties Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Editing rows/columns Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operations on objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Tools and settings Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Basic operations Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Working with slides Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Text formatting Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operations on objects Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Tools and settings Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Fill out OFORM fillable forms insert objects Decorating posts Creating a knowledge base Inserting images in posted messages Insert and adjust images Insert and format autoshapes Insert and format autoshapes Insert and format autoshapes Insert and edit charts More articles Insert and edit charts Insert and edit charts Insert and adjust images Insert and adjust images Insert text objects Insert text objects Insert and format your text Insert content controls Create fillable forms Create a Table of Contents Add and Format a Table of Figures Insert sparklines Creating a chart from start to finish Fillable forms in ONLYOFFICE Docs Support of SmartArt Support of SmartArt Support of SmartArt Adding animations Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Insert text Insert tables Insert autoshapes Insert images Create charts Manipulate objects Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Insert text Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Insert text Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Insert text Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects create fillable forms Create fillable forms Fillable forms in ONLYOFFICE Docs modify object Insert and format autoshapes Insert and edit charts Insert and edit charts Insert and adjust images Insert and adjust images Manipulate objects Manipulate objects on a slide Insert content controls Create fillable forms More articles Create a Table of Contents Creating a chart from start to finish Fillable forms in ONLYOFFICE Docs Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Manipulate objects Fill out OFORM fillable forms You can open and fill out OFORM files stored on your device. You can only fill in the fields in the the OFORM file and then download the form as a DOCX or PDF file. tap the necessary field or use the arrow buttons at the bottom of the screen to navigate between the fields. Tap to go to the previous field or to go to the next field. fill in all the necessary fields. when you select a text field, the keyboard appears. If the Characters limit setting is enabled for the field, the limit is displayed on the screen. when you select a combo box, the screen appears where you can choose the necessary option or enter your own data by tapping Enter your option. Enter the necessary data in a new window and tap OK. when you select a dropdown list, the screen appears where you can choose the necessary option. when you select a check box, the screen appears where you can check/uncheck this check box. when you select a radio button, the screen appears where you can check/uncheck this radio button. when you select an image field, the screen appears where you can choose the necessary option: Picture from library or Picture from link. undo or redo your actions using icons on the top. to clear all fields, tap the Settings icon in the right corner of the top toolbar and choose the Clear all fields option. once the form is filled in, you can download it and save it on your device as a DOCX or PDF file. Tap the Settings icon in the right corner of the top toolbar, choose the Export option, select the necessary format, then choose the location and tap Save. to quickly export the form to the PDF format and save it on your device, tap the icon on the top, then choose the location and tap Save. to print the form, tap the Settings icon in the right corner of the top toolbar and choose the Print option. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats You Might Also Like This: Close
