- Mobile Apps
- Android
- Documents
- Spreadsheet Editor
- Insert formulas
Insert formulas
To perform any calculations you can insert a needed formula manually using the common mathematical operators or insert a predefined formula - Function.
To insert a function,
- select a cell you wish to insert a function into,
- open the formula insertion panel by
- tapping the
Insert Function icon before the formula bar at the bottom, or - tapping the
icon at the top toolbar and switching to the
Function tab,
- tapping the
- select one of the commonly used functions (SUM, MIN, MAX, COUNT) or choose the necessary Category in the Categories section and select the function you need. You can also add functions manually into the formula bar. As soon as you type the first letters, a formula tip window will apear, containing proper syntax for formulas,
To view the function description, tap the
icon. - enter the function arguments either using the on-screen keyboard or dragging to select a range of cells to be included as an argument. If the function requires several arguments, they must be separated by commas.
Generally, numeric values, logical values (TRUE, FALSE), text values (must be quoted), cell references, cell range references and other functions can be used as function arguments.
- press the
Enter key on the on-screen keyboard, or tap the
button.
If you entered the formula incorrectly and want to delete all added cell content, tap the
button.
