Print the presentation
To print the current presentation, opened in the Cloud section,
- tap the
Tools icon in the right corner of the top toolbar,
- tap the
Print menu item.
A PDF file will be generated on the basis of this presentation. It can be printed out.
To print the current local presentation, opened in the On Device section,
- tap the
- tap the
Print menu item to enter the priview mode,
- at the top of the screen choose either an available Printer or tap on the Save as PDF option to generate a PDF file on the basis of this presentation,
- in the drop-down menu
specify the following parametrs:
- number of copies - enter the required number of copies of the presentation;
- number of pages - choose either a range of pages, filling the textfield in the following way: (e.g. 1-5, 8, 11-13), or tap on each checkbox below to mark the slides you want to print;
- page size - select one of the suggested paper formats;
- color - choose either black and white print or color print (only for supporting printers);
- two-sided printing - this option allows to print on both sides of a sheet of paper (only for supporting printers);
- page orientation - choose from landscape and portrait options,
- tap the
button to initialize printing.
