Create new slides
To create a new slide:
A new slide will be inserted after the selected one in the slides list.
Duplicate slides
To duplicate a slide:
- tap the necessary slide in the slides list,
- open the slide settings panel by
- tapping the
icon at the top toolbar, or
- tapping the
option in the pop-up menu,
- swipe up and tap the DUPLICATE SLIDE button.
The duplicated slide will be inserted after the selected one in the slide list.
Delete slides
To delete an unnecessary slide:
- tap the slide you want to delete in the slides list,
- tapping the
- tapping the
- swipe up and tap the DELETE SLIDE button.
