Articles with the tag:
Close
Close
Insert images
Add an image
  1. place the cursor where you want the image to be put,
  3. switch to the Image tab,
  4. select the Picture from Library local Picture from Library option to open the Media Library where you can select the necessary file.
    Note: you must have appropriate permissions on your device Media Library.
The image will be added. Now you can change its properties and position.
Adjust the shape of the image and its border
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
  1. select the image by tapping it,
  2. open the shape/image settings panel by
  3. on the SHAPE tab, tap the Style option and switch to the BORDER tab. Change the border Size by dragging the slider and select the necessary border Color.
    Tap the Replace section to replace the rectangular shape with another one selected from the menu. The shape of the image will change correspondingly.
    Reshape image
    The Wrap and Reorder sections of the SHAPE tab are the same as the ones at the IMAGE tab. If you change these options at the SHAPE tab, they will change similarly at the IMAGE tab.
  4. close the shape settings panel by tapping the Close settings panel arrow on the right or use the Return arrow on the left to return to the previous settings section.
Remove the image
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete icon local option in the pop-up menu, or
  • open the shape settings panel by tapping the Edit object icon at the top toolbar, then use the REMOVE SHAPE button at the SHAPE tab.
You Might Also Like This:
Close
