Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Change application settings
To access the application settings,
  2. tap the arrow next to the Application Settings Application settings menu item.
Currently, the following advanced settings are available:
  • Spell-checker allows to enable or disable the spell checking function.
You Might Also Like This:
Close
