Close Help Center ONLYOFFICE Documents for Android Spreadsheet Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Basic operations Navigate through your document Select, cut, copy, paste text Undo/redo your actions Page formatting Set page parameters Insert section breaks Insert page numbers Paragraph formatting Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Text formatting Set font type, size, and color Apply font decoration styles Add hyperlinks Operations on objects Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Tools and settings Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Basic operations Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operations with sheets Create or delete sheets Manage existing sheets Cell text formatting Set font type, size, and color Add hyperlinks Editing cell properties Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Editing rows/columns Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operations on objects Insert images Insert formulas Insert autoshapes Manipulate objects Tools and settings Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Basic operations Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Working with slides Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Text formatting Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operations on objects Insert tables Insert autoshapes Insert images Manipulate objects Tools and settings Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossary Video FAQ General Technology Pricing Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Apply cell style cell formatting Add borders Align data in cells Clear text, format in a cell Merge cells Select cell background color Add cell borders Apply cell style Align data in cells More articles Wrap text in a cell Merge cells Change number format Apply table styles Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Merging cells Wrapping text in excel predefined styles Apply formatting presets Insert and format tables Insert tables Set slide parameters Sort and filter data Create a Table of Contents Create and edit pivot tables Use formatted tables Create slicers for formatted tables More articles Apply formatting presets Apply cell style Apply table styles Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset: select a cell, a range of cells or the whole worksheet, open the Cell settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu and choosing the Cell menu item, swipe up to see the Cell Styles palette and tap the style you want to apply. close the cell settings panel by tapping the arrow on the right. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats You Might Also Like This: Close
