Add an image
- select the slide where you want the image to be put,
- tap the
- switch to the Image tab,
- select the
Picture from Library option to open the Media Library where you can select the necessary file.
Note: you must have appropriate permissions on your device Media Library.
The image will be added. Now you can change its properties and position.
Adjust the shape of the image and its border
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
- select the image by tapping it,
- open the settings panel by
- tapping the
icon at the top toolbar, or
- tapping the
option in the pop-up menu,
- switch to the SHAPE tab, tap the Style option and open the BORDER tab. Change the border Size by dragging the slider and select the necessary border Color.
Tap the Replace section to replace the rectangular shape with another one selected from the menu. The shape of the image will change correspondingly.
The Reorder and Align sections of the SHAPE tab are the same as the ones at the IMAGE tab. If you change these options at the SHAPE tab, they will change similarly at the IMAGE tab.
- close the shape settings panel by tapping the
arrow on the right or use the
icon on the left to return to the previous settings section.
Remove the image
Select the image by tapping on it and proceed in one of the following ways:
- tap the More option in the pop-up menu and choose the Delete menu item, or
- open the shape/image settings panel by tapping the
icon at the top toolbar. You can use both the REMOVE SHAPE button at the SHAPE tab and the REMOVE IMAGE button at the IMAGE tab.
