Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Add hyperlinks
  1. select the text passage that will get clickable and do the following:
    • tap the Insert object icon at the top toolbar to open the new object insertion panel,
    • switch to the Other tab Other tab and select the Link local icon Link option,
  2. after that the Link settings screen will appear where you can specify the hyperlink parameters:
    • Link type - select a link type you wish to insert:
      • External link - this option is selected by default. Use it to add a hyperlink leading to an external website. Enter a URL in the format http://www.example.com in the Link field below.
        External Hyperlink local
      • Internal link - use this option to add a hyperlink leading to a certain slide in the same presentation. Tap this option to select it, then return to the previous screen using the Back arrow arrow on the left. Select the necessary Slide from the list: Next, Previous, First, Last, or a certain slide number.
        Internal Hyperlink local
    • Display - enter a text that will get clickable and lead to the address/slide specified in the upper field.
      If you've selected a text passage before tapping the Insert object icon, the Display field will be filled with the selected text fragment.
  3. tap the checkmark in the upper right corner.
To follow the added link, tap the Open Link option in the pop-up menu.
  1. tap the Edit Link option in the pop-up menu and perform the actions you need:
    • edit your data and tap the checkmark in the upper right corner to save the changes.
    • use the REMOVE LINK button to delete the added hyperlink.
You Might Also Like This:
Close
