Articles with the tag:
Close
Close
Insert tables
Insert a table
  1. select the slide where you want the table to be put,
  3. switch to the Table tab and select one of the available table templates. Each template combines certain formatting parameters, such as a background color, border style, row/column banding etc.
  4. in the Table Size window that opens, set the necessary Columns and Rows number (the 3 by 3 cell table is selected by default, you can specify up to 10 rows/columns),
  5. tap OK.
The table will be added. The insertion point is placed in the upper left cell so that you can start entering data. Tap within a different cell to place the insertion point in it.
Add or delete rows or columns
  1. tap a cell within the necessary row/column,
  2. open the settings panel by
  3. switch to the TABLE tab,
  4. use the corresponding icons:
    Add column left - to insert a column at the left side from the column where the cursor is placed.
    Add column right - to insert a column at the right side from the column where the cursor is placed.
    Add row above - to insert a row above the row where the cursor is placed.
    Add row below - to insert a row below the row where the cursor is placed.
    Remove column - to remove the column where the cursor is placed.
    Remove row - to remove the row where the cursor is placed.
Or you can also double tap a table, and the corresponding Add column, Add row, Delete column, Delete row menu items will appear.
Remove the table
  1. select the table by dobble tapping on it,
  2. tap the Delete icon Delete icon in the pop-up menu.
You Might Also Like This:
Close
