Articles with the tag:
Close
Close
Try in the cloud
Connecting Rackspace Cloud Storage to ONLYOFFICE DocSpace
Connect the Rackspace Cloud Storage service to use the connected cloud storage as a third-party storage when creating backups.
Creating authorization keys
You will have to setup authorization keys for Rackspace Cloud Storage. Follow these steps:
  1. Go to Rackspace Cloud Control Panel.
  2. Sign in to your account.
  3. Click the username menu in the upper right corner of the control panel.
  4. Select the My Profile & Settings option,
  5. Scroll down to Security Settings,
  6. Click the Show link next to Rackspace API Key.
  7. Copy or write down Rackspace API Key. To connect the Rackspace service, you'll also need to specify your Rackspace username, i.e. the username that you use to log in.
  1. Click the Options icon menu in the lower left corner and select the DocSpace Settings option.
  3. In the Third-party services section, click the sliding button to the right of the Rackspace Cloud Storage logo.
  4. Enter your keys and click the Connect button.
To store your DocSpace data backup in Rackspace Cloud Storage,
  1. Go to the 'Backup' section (DocSpace Settings -> Backup -> Third-party storage).
  2. Select Rackspace Cloud Storage as the desired storage.
  3. Specify the necessary parameters and click the 'Create copy' button.
You Might Also Like This:
Close
