Панель управления
v3.1
История изменений Панели управления ONLYOFFICE
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Введение
Функция Единый вход (англ. Single Sign-On или SSO), доступная в Панели управления,Если ваш тарифный план облачной версии включает такую возможность, раздел Единый вход позволяет включить возможность аутентификации с помощью доверенной третьей стороны, используя установленные у вас сервисы SSO (Shibboleth, OneLogin или Active Directory Federation Services).
В общих чертах, технология единого входа позволяет пользователям осуществлять вход в систему только один раз, а затем получать доступ ко множеству приложений/сервисов без повторной аутентификации. Например, если на веб-портале существует несколько обширных независимых разделов (форум, чат, блог и т. д.) то, пройдя процедуру аутентификации в одном из сервисов, пользователь автоматически получает доступ ко всем остальным, что избавляет его от многократного ввода данных своей учётной записи.
SSO - это всегда совместная работа двух приложений: поставщика учетных записей (англ. Identity Provider, далее по тексту сокращенно "IdP") и поставщика сервиса (англ. Service Provider, далее по тексту сокращенно "SP").
ONLYOFFICE SSO реализует только SP. В качестве IdP может выступать множество различных провайдеров, но ONLYOFFICE был протестирован только со следующими сервисами: Shibboleth, OneLogin и AD FS.
Используя SSO-аутентификацию, вы получаете следующие преимущества:
- Повышенное удобство. Пользователи получают более быстрый и простой способ доступа на портал, не требующий запоминания множества логинов и паролей.
- Повышенный уровень безопасности. ONLYOFFICE не хранит пароли пользователей ни в каком виде, а использует результаты аутентификации на стороне поставщика учетных записей.
- Удобное администрирование. Вся необходимая информация о пользователе передается в аутентификационном токене. При изменении информации о пользователе на стороне поставщика учетных записей данные автоматически обновятся на портале при последующей аутентификации с помощью SSO. Если профиль пользователя отсутствует на портале, он будет автоматически создан при первом входе пользователя на портал с помощью учетных данных SSO.
В ONLYOFFICE SSO-аутентификация реализована на базе безопасного и широко используемого стандарта SAML. SAML (Security Assertion Markup Language, язык разметки декларации безопасности) - стандарт на базе языка XML, позволяющий передавать данные об аутентификации и авторизации между поставщиком учетных записей и поставщиком сервиса через токены безопасности, содержащие утверждения.
В данной статье описан процесс включения SSO в целом. Если вас интересуют конкретные настройки или примеры для определенных поставщиков учетных записей, обратитесь к нашим статьям о настройке поставщика сервиса ONLYOFFICE и поставщиков учетных записей Shibboleth, OneLogin или AD FS.
Включение SSO
Чтобы включить и настроить на портале аутентификацию с помощью SSO, необходимо выполнить два следующих основных шага:
- Зарегистрировать поставщика учетных записей на странице SSO в Панели управления ONLYOFFICE. Информацию, которую требуется указать, можно найти в вашем аккаунте поставщика учетных записей.
Если вы хотите использовать SSO при подключении Десктопных редакторов ONLYOFFICE к , отключите Приватные комнаты в Панели управления.
- Зарегистрировать ONLYOFFICE в качестве проверенного поставщика сервиса в аккаунте поставщика учетных записей. Эта процедура различается в зависимости от выбранного поставщика учетных записей.
Каждый портал можно одновременно интегрировать только с одним поставщиком учетных записей.
Регистрация поставщика учетных записей в поставщике сервиса ONLYOFFICE
Для регистрации поставщика учетных записей в ONLYOFFICE SP используйте раздел Настройки поставщика сервиса ONLYOFFICE на странице SSO.
Поставщик учетных записей (англ. Identity Provider, далее по тексту сокращенно "IdP") - это провайдер идентификации, который создает, поддерживает и управляет информацией об идентификации клиентов и обеспечивает аутентификацию клиентов для других провайдеров услуг внутри объединения. Поставщиками учетных записей являются OneLogin, ADFS и другие. Поставщик сервиса - сторона, которая предоставляет веб-сервисы и использует услуги доверенного поставщика учетных записей для аутентификации пользователей. В данном случае поставщиком сервиса является ONLYOFFICE.
Вы можете включить SSO на базе стандарта SAML для обмена данными об аутентификации и авторизации между поставщиком учетных записей и поставщиком сервиса:
- SAML (Security Assertion Markup Language, язык разметки декларации безопасности) - стандарт на базе языка XML, позволяющий передавать данные об аутентификации и авторизации между поставщиком учетных записей и поставщиком сервиса через токены безопасности, содержащие утверждения.
Повышенный уровень безопасности обеспечивается за счет того, что ONLYOFFICE не хранит пароли пользователей ни в каком виде, а использует результаты аутентификации на стороне поставщика учетных записей. Вся необходимая информация о пользователе передается в аутентификационном токене. При изменении информации о пользователе на стороне поставщика учетных записей данные автоматически обновятся на портале при последующей аутентификации с помощью SSO (обратите внимание, что данные синхронизируются только в одном направлении: от Поставщика учетных записей к онлайн-офису).
После взаимной настройки Поставщика учетных записей и ONLYOFFICE для обеспечения работы SSO, процесс аутентификации пользователей с помощью SSO будет выполняться на стороне Поставщика учетных записей. ONLYOFFICE будет получать аутентификационный токен (SAML) от Поставщика учетных записей. После проверки токена (с использованием цифровых подписей и времени жизни токена), ONLYOFFICE разрешает пользователю получить доступ к порталу.
Включение SSO
Чтобы включить и настроить на портале аутентификацию с помощью SSO, действуйте следующим образом:
Прежде чем настраивать Поставщика сервиса, проверьте настройки Поставщика учетных записей.
- На портале ONLYOFFICE перейдите в Панель управления и откройте страницу SSO в разделе НАСТРОЙКИ ПОРТАЛА на левой боковой панели.
Перейдите на страницу Настроек портала. Для этого нажмите значок
в правом верхнем углу.
- В разделе Интеграция на левой боковой панели нажмите на ссылку Единый вход.
- Нажмите на переключатель Включить аутентификацию с помощью технологии единого входа.
Включите переключатель Включить аутентификацию с помощью технологии единого входа под заголовком Единый вход.
- Заполните требуемые поля в разделе Настройки поставщика сервиса ONLYOFFICE. Нужную информацию можно указать несколькими разными способами:
- Введите URL-адрес файла метаданных. Если метаданные поставщика учетных записей доступны извне по ссылке, вставьте эту ссылку в поле URL-адрес XML-файла метаданных IdP и нажмите кнопку Загрузить данные. Когда данные будут загружены, все требуемые параметры автоматически отобразятся в расширенной форме.
- Загрузите файл метаданных. Если поставщик учетных записей предоставляет файл метаданных, используйте кнопку Выбрать файл, чтобы найти файл, сохраненный на локальной машине. Когда файл будет загружен, все требуемые параметры автоматически отобразятся в расширенной форме.
- Укажите требуемые параметры вручную. Если файл метаданных недоступен, введите нужные параметры вручную. Для получения нужных значений обратитесь к администратору вашего поставщика учетных записей.
Доступны следующие параметры:
- Идентификатор сущности поставщика учетных записей (обязательное поле) - идентификатор поставщика учетных записей или URL-адрес, который будет использоваться поставщиком сервиса, чтобы однозначно идентифицировать поставщика учетных записей.
https://example.com/idp/shibboleth
где example.com - это доменное имя вашего SSO-сервиса
- URL-адрес конечной точки единого входа IdP (обязательное поле) - URL-адрес, используемый для единого входа на стороне поставщика учетных записей. Это адрес конечной точки в поставщике учетных записей, на который поставщик сервиса отправляет запросы аутентификации.
Задайте нужный тип Привязки, выбрав одну из соответствующих радиокнопок. Привязки определяют, каким образом запросы и ответы аутентификации передаются между поставщиком учетных записей и поставщиком сервиса по стандартному транспортному протоколу: с помощью привязки HTTP POST или привязки HTTP Redirect.
- URL-адрес конечной точки единого выхода IdP - URL-адрес, используемый для единого выхода на стороне поставщика сервиса. Это адрес конечной точки в поставщике учетных записей, на который поставщик сервиса отправляет запросы и ответы выхода.
Задайте нужный тип Привязки, выбрав одну из соответствующих радиокнопок. Привязки определяют, каким образом запросы и ответы выхода передаются между поставщиком учетных записей и поставщиком сервиса по стандартному транспортному протоколу: с помощью привязки HTTP POST или привязки HTTP Redirect.
- Формат NameId - параметр NameID позволяет поставщику сервиса идентифицировать пользователя. Выберите в списке один из доступных форматов.
Вы можете кастомизировать кнопку, используемую для входа на портал с помощью сервиса Single Sign-on на странице аутентификации ONLYOFFICE. Это можно сделать с помощью поля Пользовательская надпись для кнопки входа в разделе Настройки поставщика сервиса ONLYOFFICE.
Можно также добавить сертификаты поставщика учетных записей и поставщика сервиса.
Открытые сертификаты поставщика учетных записей
В разделе Открытые сертификаты поставщика учетных записей можно добавить открытые сертификаты поставщика учетных записей, используемые поставщиком сервиса для проверки запросов и ответов от поставщика учетных записей.
Если вы загрузили метаданные поставщика учетных записей, эти сертификаты будут автоматически добавлены в Панель управленияна портал. В противном случае сертификаты можно найти в вашем аккаунте поставщика учетных записей. Чтобы добавить сертификат вручную, нажмите кнопку Добавить сертификат. Откроется окно Новый сертификат. Вставьте сертификат в поле Открытый сертификат и нажмите кнопку OK.
Задайте дополнительные параметры для сертификатов, поставив соответствующие галочки.
Укажите, подписи каких запросов/ответов, отправляемых от поставщика учетных записей поставщику сервиса, следует проверять:
- Проверять подпись ответов аутентификации - чтобы проверять подписи ответов аутентификации SAML, отправляемых поставщику сервиса.
- Проверять подпись запросов выхода - чтобы проверять подписи запросов выхода SAML, отправляемых поставщику сервиса.
- Проверять подпись ответов выхода - чтобы проверять подписи ответов выхода SAML, отправляемых поставщику сервиса.
Выберите нужный алгоритм из списка Стандартный алгоритм проверки подписи: rsa-sha1
, rsa-sha256
или rsa-sha512
Настройки по умолчанию используются только в тех случаях, если в метаданных поставщика учетных записей не указано, какой алгоритм должен использоваться.
Можно редактировать или удалить добавленные сертификаты, используя соответствующую ссылку.
Сертификаты поставщика сервиса
В разделе Сертификаты поставщика сервиса можно добавить сертификаты поставщика сервиса, используемые для подписи и шифрования запросов и ответов от поставщика сервиса.
Если ваш поставщик учетных записей требует, чтобы входящие данные были подписаны и/или зашифрованы, создайте или добавьте сертификаты в этом разделе.
Нажмите кнопку Добавить сертификат. Откроется окно Новый сертификат. Вы можете сгенерировать самоподписанный сертификат или добавить уже имеющийся сертификат в поле Открытый сертификат, а соответствующий ему закрытый ключ - в поле Закрытый ключ. В списке Использовать для выберите один из доступных вариантов: signing
, encrypt
, signing and encrypt
. Когда все будет готово, нажмите кнопку OK.
В зависимости от предназначения сертификата, выбранного в списке Использовать для при загрузке/генерации сертификата, указываются дополнительные параметры сертификата. Следующие параметры определяют, какие запросы/ответы, отправляемые от поставщика сервиса поставщику учетных записей, следует подписывать:
- Подписывать запросы аутентификации - чтобы поставщик сервиса подписывал запросы аутентификации SAML, отправляемые поставщику учетных записей.
- Подписывать запросы выхода - чтобы поставщик сервиса подписывал запросы выхода SAML, отправляемые поставщику учетных записей.
- Подписывать ответы выхода - чтобы поставщик сервиса подписывал ответы выхода SAML, отправляемые поставщику учетных записей.
Если вы выбрали опцию encrypt
или signing and encrypt
в списке Использовать для, также будет отмечен параметр Расшифровывать утверждения. Расшифровка осуществляется с помощью соответствующего Закрытого ключа.
Выберите нужные алгоритмы из списков:
- Алгоритм подписи:
rsa-sha1
, rsa-sha256
или rsa-sha512
- Стандартный алгоритм расшифровки:
aes128-cbc
, aes256-cbc
или tripledes-cbc
Сопоставление атрибутов
В разделе Сопоставление атрибутов можно указать соответствие полей модуля Люди ONLYOFFICE атрибутам пользователя, которые будут возвращаться из поставщика учетных записей. Когда пользователь осуществляет вход в ONLYOFFICE SP с использованием учетных данных SSO, ONLYOFFICE SP получает требуемые атрибуты и заполняет полное имя и адрес электронной почты для учетной записи пользователя значениями, полученными от поставщика учетных записей. Если такого пользователя нет в модуле "Люди", он будет создан автоматически. Если информация о пользователе была изменена на стороне поставщика учетных записей, данные также обновятся в поставщике сервиса.
Доступны следующие атрибуты:
- Имя (обязательное поле) - атрибут в записи пользователя, соответствующий имени пользователя.
- Фамилия (обязательное поле) - атрибут в записи пользователя, соответствующий фамилии пользователя.
- Электронная почта (обязательное поле) - атрибут в записи пользователя, соответствующий адресу электронной почты пользователя.
- Местоположение - атрибут в записи пользователя, соответствующий местоположению пользователя.
- Должность - атрибут в записи пользователя, соответствующий должности пользователя.
- Телефон - атрибут в записи пользователя, соответствующий номеру телефона пользователя.
Дополнительные параметры
Настройка Скрыть страницу аутентификации позволяет cкрыть страницу аутентификации по умолчанию и автоматически перенаправлять на сервис SSO.
ВажноЕсли вам необходимо восстановить страницу аутентификации по умолчанию (чтобы иметь доступ к порталу, если ваш сервер IDP выйдет из строя), можно добавить ключ /Auth.aspx?skipssoredirect=true
после доменного имени портала в адресной строке браузера.
Когда все параметры будут указаны в Панели управленияна портале, нажмите кнопку Сохранить. Откроется раздел Метаданные поставщика сервиса ONLYOFFICE.
Регистрация ONLYOFFICE в качестве проверенного поставщика сервиса в поставщике учетных записей
Теперь необходимо добавить ONLYOFFICE в качестве проверенного поставщика сервиса в ваш аккаунт поставщика учетных записей, указав в поставщике учетных записей метаданные ONLYOFFICE SP.
Для получения нужных данных обратитесь к разделу Метаданные поставщика сервиса ONLYOFFICE на странице SSO. Убедитесь, что данные поставщика сервиса доступны публично. Для этого нажмите кнопку Скачать XML-файл метаданных поставщика сервиса. Содержимое XML-файла отобразится в новой вкладке браузера. Сохраните данные как XML-файл, чтобы можно было загрузить его в поставщик учетных записей.
Можно также вручную скопировать отдельные параметры, нажав на кнопку Копировать в буфер обмена в соответствующих полях.
- Идентификатор сущности поставщика сервиса (ссылка на XML-файл метаданных) - URL-адрес XML-файла поставщика сервиса. Файл можно скачать, и он будет использоваться поставщиком учетных записей, чтобы однозначно идентифицировать поставщика сервиса. По умолчанию файл размещается по следующему адресу: http://example.com/sso/metadata, где example.com - это доменное имя или публичный IP-адрес портала ONLYOFFICE.
- URL-адрес службы обработчика утверждений поставщика сервиса (поддерживаются привязки Redirect и POST) - URL-адрес поставщика сервиса, по которому он получает и обрабатывает утверждения от поставщика учетных записей. По умолчанию используется следующий адрес: http://example.com/sso/acs, где example.com - это доменное имя или публичный IP-адрес портала ONLYOFFICE.
- URL-адрес единого выхода поставщика сервиса (поддерживаются привязки Redirect и POST) - URL-адрес, используемый для единого выхода на стороне поставщика учетных записей. Это адрес конечной точки в поставщике сервиса, по которому он получает и обрабатывает запросы и ответы выхода от поставщика учетных записей. По умолчанию используется следующий адрес: http://example.com/sso/slo/callback, где example.com - это доменное имя или публичный IP-адрес портала ONLYOFFICE.
Эти параметры и содержимое XML-файла различаются в зависимости от настроек вашего портала, например, если вы переключите портал на HTTPS или привяжете доменное имя, данные параметры тоже изменятся и потребуется заново настраивать поставщик учетных записей.
Вход в ONLYOFFICE SP
После того как Единый вход включен и настроен, процесс входа осуществляется следующим образом:
- Пользователь запрашивает доступ к ONLYOFFICE, нажав на кнопку Single Sign-on (название кнопки может отличаться, если вы указали свой вариант при настройке ONLYOFFICE SP) на странице аутентификации портала ONLYOFFICE (единый вход, инициированный поставщиком сервиса).
- Если всё настроено верно в SP и IdP, ONLYOFFICE отправляет запрос аутентификации поставщику учетных записей и перенаправляет пользователя на страницу поставщика учетных записей, где пользователю надо ввести учетные данные.
- Если пользователь ещё не осуществил вход в поставщик учетных записей, он вводит свои учетные данные в IdP.
- Поставщик учетных записей создает ответ аутентификации, содержащий данные пользователя, и отправляет его поставщику сервиса ONLYOFFICE.
- ONLYOFFICE получает ответ аутентификации от поставщика учетных записей и проверяет его подлинность.
- Если подлинность ответа подтверждена, ONLYOFFICE позволяет пользователю войти (если такого пользователя нет на портале, он будет создан автоматически, а если данные были изменены в IdP, они будут обновлены).
Можно также использовать страницу входа на стороне поставщика учетных записей (единый вход, инициированный поставщиком учетных записей), ввести учетные данные и получить доступ к порталу ONLYOFFICE без повторной аутентификации.
Выход из ONLYOFFICE SP
Выход можно осуществить двумя доступными способами:
- С портала ONLYOFFICE, используя пункт меню Выйти (в этом случае отправляется запрос от IdP на выход). Пользователь также должен автоматически выйти из IdP, если он вышел из всех остальных приложений, к которым ранее получил доступ с помощью SSO-аутентификации.
- Со страницы выхода поставщика учетных записей.
Редактирование профилей пользователей, созданных с помощью SSO
Пользователи, созданные с помощью SSO-аутентификации, отмечены в списке пользователей значком SSO для администраторов портала.
Возможность редактирования профилей этих пользователей в модуле "Люди" ограничена. Поля профиля пользователя, созданные с помощью SSO-аутентификации, заблокированы для редактирования в модуле "Люди". Информацию о таких пользователях можно изменить только на стороне поставщика учетных записей.
