Parameter |
Description |
Type |
Default |
wopi.enable
Defines if WOPI is enabled or not. |
boolean |
false |
wopi.host
Defines the WOPI host (host name or IP address). |
string |
wopi.htmlTemplate
Defines a path to the WOPI HTML template. |
string |
"../../web-apps/apps/api/wopi" |
wopi.wopiZone
Defines a zone that the Document Server uses to navigate the browser to the WOPI application. |
string |
"external-http" |
wopi.favIconUrlWord
Defines a path to the favicon for the document editor. |
string |
"/web-apps/apps/documenteditor/main/resources/img/favicon.ico" |
wopi.favIconUrlCell
Defines a path to the favicon for the spreadsheet editor. |
string |
"/web-apps/apps/spreadsheeteditor/main/resources/img/favicon.ico" |
wopi.favIconUrlSlide
Defines a path to the favicon for the presentation editor. |
string |
"/web-apps/apps/presentationeditor/main/resources/img/favicon.ico" |
wopi.fileInfoBlockList
Defines a list of WOPI file information parameters that are blocked when sending this array to the browser. However, these parameters are available on the server. |
array of strings |
["FileUrl"] |
wopi.wordView
Defines the file types that can be viewed in the document editor. |
array of strings |
["pdf", "djvu", "xps", "oxps", "doc", "dotx", "dotm", "dot", "fodt", "ott", "rtf", "mht", "html", "htm", "xml", "epub", "fb2"] |
wopi.wordEdit
Defines the file types that can be edited in the document editor. |
array of strings |
["docx", "docm", "docxf", "oform", "odt", "txt"] |
wopi.cellView
Defines the file types that can be viewed in the spreadsheet editor. |
array of strings |
["xls", "xlsb", "xltx", "xltm", "xlt", "fods", "ots"] |
wopi.cellEdit
Defines the file types that can be edited in the spreadsheet editor. |
array of strings |
["xlsx", "xlsm", "ods", "csv"] |
wopi.slideView
Defines the file types that can be viewed in the presentation editor. |
array of strings |
["ppt", "ppsx", "ppsm", "pps", "potx", "potm", "pot", "fodp", "otp"] |
wopi.slideEdit
Defines the file types that can be edited in the presentation editor. |
array of strings |
["pptx", "pptm", "odp"] |
wopi.publicKey
Defines the public key that the integrator uses to check the private key. |
string |
"BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVShU7rcUeLQsd/0pkflh5+um4YKEZhm4Mou3vstp5p12NeffyK1WFZF7q4jB7jclAslYKQsP82YY3DcRwu5Tl/+W0ifVcXze0mI7v1reJ12pKn8ifRiq+0q5oJST3TRSrvmjLg9Gt3ozhVIt2HUi3La7Qh40YOAUXm0g/hUq2BepeOp1C7WSvaOFHXe6Hqq" |
wopi.modulus
Defines the RSA modulus in the Base64-encoded format that is used to retrieve the public key. |
string |
"qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0OJR3LpToVRZhzSkYQrxnERJmF3bhR5yF8Zn+3BoSiUpVOCAvJRAYl8cAIs3BwQcTEyXJjnt+wW5Q1VyKr+bXp/39+tnugQeTe1jjdPy6rOTftQwzjro81oZpOMazwwR1aeQuQWCrmHQZqyV3Rvo6X3xYlOQnlo1/w==" |
wopi.exponent
Defines the RSA exponent in the Base64-encoded format that is used to retrieve the public key. |
string |
"AQAB" |
wopi.privateKey
Defines the private key that signs the Document Server request. |
string |
"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" |
wopi.publicKeyOld
Defines the old public key that the integrator used to check the private key. |
string |
wopi.modulusOld
Defines the old RSA modulus in the Base64-encoded format that was used to retrieve the public key. |
string |
wopi.exponentOld
Defines the old RSA exponent in the Base64-encoded format that was used to retrieve the public key. |
string |
"AQAB" |
wopi.privateKeyOld
Defines the old private key that signed the Document Server request. |
string |
wopi.refreshLockInterval
Defines the interval time in minutes for refreshing the lock on a file by resetting its automatic expiration timer to 30 minutes. |
string |
"10m" |
These parameters define the WOPI protocol configuration.
Example
"wopi": {
"enable": false,
"host" : "",
"htmlTemplate" : "../../web-apps/apps/api/wopi",
"wopiZone" : "external-http",
"favIconUrlWord" : "/web-apps/apps/documenteditor/main/resources/img/favicon.ico",
"favIconUrlCell" : "/web-apps/apps/spreadsheeteditor/main/resources/img/favicon.ico",
"favIconUrlSlide" : "/web-apps/apps/presentationeditor/main/resources/img/favicon.ico",
"fileInfoBlockList" : ["FileUrl"],
"wordView": ["pdf", "djvu", "xps", "oxps", "doc", "dotx", "dotm", "dot", "fodt", "ott", "rtf", "mht", "html", "htm", "xml", "epub", "fb2"],
"wordEdit": ["docx", "docm", "docxf", "oform", "odt", "txt"],
"cellView": ["xls", "xlsb", "xltx", "xltm", "xlt", "fods", "ots"],
"cellEdit": ["xlsx", "xlsm", "ods", "csv"],
"slideView": ["ppt", "ppsx", "ppsm", "pps", "potx", "potm", "pot", "fodp", "otp"],
"slideEdit": ["pptx", "pptm", "odp"],
"publicKey": "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVShU7rcUeLQsd/0pkflh5+um4YKEZhm4Mou3vstp5p12NeffyK1WFZF7q4jB7jclAslYKQsP82YY3DcRwu5Tl/+W0ifVcXze0mI7v1reJ12pKn8ifRiq+0q5oJST3TRSrvmjLg9Gt3ozhVIt2HUi3La7Qh40YOAUXm0g/hUq2BepeOp1C7WSvaOFHXe6Hqq",
"modulus": "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0OJR3LpToVRZhzSkYQrxnERJmF3bhR5yF8Zn+3BoSiUpVOCAvJRAYl8cAIs3BwQcTEyXJjnt+wW5Q1VyKr+bXp/39+tnugQeTe1jjdPy6rOTftQwzjro81oZpOMazwwR1aeQuQWCrmHQZqyV3Rvo6X3xYlOQnlo1/w==",
"exponent": "AQAB",
"privateKey": "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",
"publicKeyOld": "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVShU7rcUeLQsd/0pkflh5+um4YKEZhm4Mou3vstp5p12NeffyK1WFZF7q4jB7jclAslYKQsP82YY3DcRwu5Tl/+W0ifVcXze0mI7v1reJ12pKn8ifRiq+0q5oJST3TRSrvmjLg9Gt3ozhVIt2HUi3La7Qh40YOAUXm0g/hUq2BepeOp1C7WSvaOFHXe6Hqq",
"modulusOld": "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0OJR3LpToVRZhzSkYQrxnERJmF3bhR5yF8Zn+3BoSiUpVOCAvJRAYl8cAIs3BwQcTEyXJjnt+wW5Q1VyKr+bXp/39+tnugQeTe1jjdPy6rOTftQwzjro81oZpOMazwwR1aeQuQWCrmHQZqyV3Rvo6X3xYlOQnlo1/w==",
"exponentOld": "AQAB",
"privateKeyOld": "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",
"refreshLockInterval": "10m"
