Chiudi Centro assistenza User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presentation Editor User Guides about Editors ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors User Guides Watch video ONLYOFFICE Documents for Android Document Editor overview ONLYOFFICE Documents for Android Spreadsheet Editor overview ONLYOFFICE Documents for Android Presentation Editor overview How to open and save docs to different formats using ONLYOFFICE Documents for Android How to share files using ONLYOFFICE Documents for Android How to organize files using ONLYOFFICE Documents for Android How to connect ONLYOFFICE Documents for Android to Cloud How to connect ONLYOFFICE Documents for Android to Personal How to connect ONLYOFFICE Documents for Android to Server How to edit documents stored on Nextcloud with ONLYOFFICE on your Android device ONLYOFFICE Documents for Android Mostra sommario Nascondi sommario The Documents app for Android allows you to access the files stored in your ONLYOFFICE account on your mobile device. Using this app, you can view, create and edit text documents, spreadsheets and presentations, manage your documents as well as connect third-party cloud storages. You can provide different access types to your files and edit documents collaboratively with other portal users or share files via external links. ONLYOFFICE Documents app for Android Documents app for Android changelog Getting Started ONLYOFFICE Documents for Android - Overview Common operations for Android Manage files Open or create new files and folders Share files and folders Document Editor for Android Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Strumenti e impostazioni Use the Find and Replace function Download and print your document View document information Spreadsheet Editor for Android Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change spreadsheet settings Download and print spreadsheet View spreadsheet information Presentation Editor for Android Operazioni principali Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change presentation settings Download your presentation Print presentation View presentation information
