Chiudi Centro assistenza ONLYOFFICE Documents for Android Document Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Strumenti e impostazioni Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Manipulate objects Strumenti e impostazioni Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Create lists formattazione paragrafo Aggiungere bordi Allineare testo nella riga o paragrafo Copiare/cancellare la formattazione del testo Impostare interlinea di paragrafo Impostare le tabulazioni Inserire un capolettera Inserire interruzione di pagina Modificare rientri di paragrafo More articles Impostare un livello di struttura del paragarfo Selezionare colore sfondo per un paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Insert line breaks Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Change text indents Set paragraph line spacing Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Align text in a text box Change text indents Set paragraph line spacing Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Align text in a text box Change text indents Set paragraph line spacing Create lists Creating a hanging indent creare elenchi Creare elenchi Creare elenchi Create lists Create lists Create lists Create lists Create lists Create lists More articles Create lists Create lists formattazione elenco Creare elenchi Creare elenchi Create lists Create lists Create lists Create lists Create lists Create lists More articles Create lists Create lists To create a list in your document, place the cursor to the position where a list will be started (this can be a new line or the already entered text), open the text and paragraph settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu, on the TEXT tab, swipe up to see all the settings, select the list type you would like to start: tap the Bullets option to create an Unordered list with markers and select the marker type, tap the Numbers option to create an Ordered list with digits or letters and select how the list is going to look like, close the paragraph settings panel by tapping the arrow on the left. now each time you press the Enter key at the end of the line a new ordered or unordered list item will appear. To stop that, tap the key and continue with the common text paragraph. You can also change the text indentation in the lists using the Decrease Indent and Increase Indent icons on the TEXT tab. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
