Voci con l'etichetta :
Chiudi
Chiudi
Merge cells
Merge cells
You can merge two or more adjacent cells into one cell. Select two cells or a range of cells and tap the Merge option in the pop-up menu that appears. Confirm the operation by pressing OK in a new window that opens.
Note: only the data in the upper-left cell of the selected range will remain in the merged cell. Data in other cells of the selected range will be deleted.
The cells of the selected range will be merged and the data will be aligned by the left side (for text) or by the right side (for numeric values).
Unmerge cells
To unmerge the previously merged cell, double-tap it, then tap the Unmerge option in the pop-up menu that appears. The data of the merged cell will be displayed in the upper-left cell.
Chiudi
