Voci con l'etichetta :
Chiudi
Chiudi
Select cell background color
To apply a background color to a certain cell/cell range or change the current one,
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Edit icon local option in the pop-up menu and choosing the Cell menu item,
  3. tap the Fill color option to open the color palette panel,
    Cell Background settings local
  4. select the necessary color on the Theme Colors or Standard Colors palette,
  5. close the fill color settings panel by tapping the Back arrow on the left.
To clear the background color of a certain cell, use the No Fill No Fill icon on the Standard Colors palette.
Chiudi
