Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Apply cell style
You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Edit icon local option in the pop-up menu and choosing the Cell menu item,
  3. swipe up to see the Cell style palette and tap the style you want to apply.
    Cell styles palette
  4. return to the previous screen by tapping the Back arrow on the left and сlose the cell settings panel by tapping the Close settings panel icon on the right.
Chiudi
