Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Manage slides
Create new slides
To create a new slide:
  • tap the Insert object icon at the top toolbar to open the new object insertion panel,
  • on the Slide Slide tab, select a slide with the necessary layout.
    You can change the layout of the added slide anytime. For additional information on how to do that refer to the Change slide layout section of this guide.
You cal also tap the Insert object button in the slide list.
Insert slide
A new slide will be inserted after the selected one in the slides list.
Duplicate slides
To duplicate a slide:
    1. tap the necessary slide in the slides list,
    2. open the slide settings panel by
    3. swipe up and tap the DUPLICATE SLIDE button,
      or
    1. double tap the necessary slide in the slides list,
    2. tap the Duplicate slide option in the context menu.
The duplicated slide will be inserted after the selected one in the slide list.
Move slides
To move an existing slide:
  1. touch and hold the necessary slide in the slides list,
  2. without lifting your finger, drag the slide to the necessary place in the list.
Hide slides
To hide an existing slide:
  2. tap the Hide slide option in the context menu.
To show the hidden slide:
  1. double tap the hidden slide in the slides list,
  2. tap the Show slide option in the context menu.
Delete slides
To delete an unnecessary slide:
    1. tap the slide you want to delete in the slides list,
    3. swipe up and tap the DELETE SLIDE button,
      or
    2. tap the Delete slide option in the context menu.
Chiudi
