Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Insert tables
Insert a table
  1. place the cursor where you want the table to be put,
  3. switch to the Table icon Table tab and select one of the available table templates. Each template combines certain formatting parameters, such as a background color, border style, row/column banding etc.
  4. in the Table size window that opens, set the necessary Columns and Rows number (the 3 by 3 cell table is selected by default, you can specify up to 10 rows/columns),
  5. tap Accept.
The table will be added. The insertion point is placed in the upper left cell so that you can start entering data. Tap within a different cell to place the insertion point in it.
Add or delete rows or columns
  1. tap a cell within the necessary row/column,
  2. open the text/object settings panel by
  3. switch to the Table tab,
  4. use the corresponding icons:
    Add column left - to insert a column at the left side from the column where the cursor is placed.
    Add column right - to insert a column at the right side from the column where the cursor is placed.
    Add row above - to insert a row above the row where the cursor is placed.
    Add row below - to insert a row below the row where the cursor is placed.
    Remove column - to remove the column where the cursor is placed.
    Remove row - to remove the row where the cursor is placed.
The corresponding options are also located in the pop-up menu.
Remove the table
  1. select the table by tapping on one of its edges and dragging the Select top and Select bottom handles so they cover the entire table,
  2. tap the Delete icon Delete icon in the pop-up menu.
Chiudi
