Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Apply font decoration styles
To apply the formatting to the text, select it and open the text and paragraph settings panel by:
  • tapping the More option in the pop-up menu and choosing the Edit menu item,
On the TEXT tab, use one of the available settings. Use the Return icon on the left to return to the previous settings section.
Text settings
Bold Bold - tap this icon to make the font bold giving it more weight.
Italic Italic - tap this icon to make the font italicized giving it some right side tilt.
Underline Underline - tap this icon to make the text underlined with the line going under the letters.
Strikethrough Strikethrough - tap this icon to make the text struck out with the line going through the letters.
Swipe up and tap the Additional Formatting option. Use one of the following options:
Text advanced settings
  • Strikethrough is used to make the text struck out with the line going through the letters.
  • Double Strikethrough is used to make the text struck out with the double line going through the letters.
  • Superscript is used to make the text smaller and place it to the upper part of the text line, e.g. as in fractions.
  • Subscript is used to make the text smaller and place it to the lower part of the text line, e.g. as in chemical formulas.
  • Small Caps is used to make all letters lower case.
  • All Caps is used to make all letters upper case.
  • Letter Spacing is used to set the space between the characters. Tap Downwards arrow or Upwards arrow arrows to decrease or increase the current value.
Close the text settings panel by tapping the Close settings panel arrow on the right.
Chiudi
