Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Set font type, size, and color
Select the text you want the formatting to be applied to and open the settings panel by:
Switch to the TEXT tab and use one of the available settings. Use the Return icon on the left to return to the previous settings section.
Text settings
  • Tap the font name displayed on the left (e.g. Arial) and select a different font from the list of the available ones.
  • Tap the font size displayed on the right (e.g. 44 pt) and use the Downwards arrow or Upwards arrow arrows to decrease or increase the current value.
  • Font Color - is used to change the color of the characters in the text. Tap this option to open the the color palettes panel (swipe up to see more colors). Select the necessary color on the Theme Colors or Standard Colors palette or create your own Custom Color.
    1. go to the Add Custom Color menu,
      Custom color
    2. using the color palette, choose the necessary color and select its hue level,
    3. tap the Enabled button to apply the color to the selected text.
    Currently, Custom color function is not available when editing a local presentation using the On Device section
Close the text settings panel by tapping the Close settings panel arrow on the right.
Chiudi
