Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Change slide layout
To customize your presentation, you can change the slide layout for each separate slide. To change a slide layout:
  1. in the slide list on the left, tap the slide you want to apply a new layout to,
  2. open the slide settings panel by
  3. tap the Layout menu item,
  4. select the necessary layout (swipe up to see more layouts),
    Layout gallery
    Note: currently, the following layouts are available: Title Slide, Title and Content, Section Header, Two Content, Comparison, Title Only, Blank, Content with Caption, Picture with Caption, Title and Vertical Text, Vertical Title and Text.
  5. close the slide settings panel by tapping the Close settings panel arrow on the right.
Chiudi
