Working with Public rooms
Public rooms are intended to simplify file sharing with external users, i.e., those who are not a member of your workspace.
You can provide people with external links to view documents without registration. The room will be available to anyone with the link. By default, external users will have View Only permission for all the files in a Public room, but you can create additional links with different access rights.
You can also embed this room into any web interface so that people can access files stored in the room directly from your website or service.
Key features
  • Creating external links for accessing multiple documents without registration
  • Adding several links with different settings
  • Protecting links with a password, setting restrictions on copying, downloading, and printing
  • Time limit for additional links
  • Embedding rooms into web pages to demonstrate a set of documents to all visitors
  • Using third-party services (Box, Dropbox, etc.) as data storage
Possible use cases
  • Demonstrating ready documentation to partners, customers, or other third parties
  • Publishing a set of documents on a website or blog
  • Sharing content both from the workspace and a third-party service connected as storage
For example, you need to share demo materials or project documentation with your partners. Let's see how this can be done with Public rooms.
Step 1. Create a Public room
Create a new Public room in a few easy steps:
  1. Go to the Rooms app and click the New room button or the Plus icon Plus icon.
  2. Select the Public room type.
  3. Enter the room Name.
  4. Optionally, you can add tags in the Tags field or change the room icon.
  5. Optionally, set the Storage quota for the room, or check the Disable quota for this room box to turn the storage limit off.
  6. Optionally, turn on the Third-party storage switcher to use third-party services as data storage for this room. You can create a new folder or select an existing one in the connected storage. For more details on connecting third-party storages, read this instruction.
    If you want to connect a third-party service, this can be done at the room creation step only, not when editing existing rooms.
  7. Click Create.
Public rooms Public rooms
Step 2. Add documents to the room
A newly created room displays the Welcome to the Public room screen with quick actions: Create a new file, Invite people, Upload from storage (from the Files or Rooms app), and Upload from device.
The same operations are available via the New button above the list of documents:
  • Document, Spreadsheet, Presentation – create a new file online.
  • PDF Form – create a new form from Blank or From text file.
  • Folder – create a new folder.
  • Template gallery – create a file on the base of one of the ready-made templates.
  • Upload files / Upload folder – upload the existing files and folders from your device.
All available options for working with documents in rooms are listed here.
Step 3. Add authorized users to the room
If necessary, you can add guests or users registered in your workspace to the room for working with documents and managing its contents.
The following permission levels are available in the Public room:
  • Room manager (Paid) – manage the assigned rooms, invite new users, and assign roles below their level.
  • Content creator – create and edit files in the room, but cannot manage users or access settings.
To add a Room manager, you should select a Room admin or a Full admin from the existing workspace contacts.
To invite guests and users:
  1. Go to the room Info -> Contacts screen and use the Invite contacts icon Invite contacts icon.
  2. Turn on the Invite via link switcher to create a universal link for self-authorization in the room as a guest. The link is copied to the clipboard and its expiration date is displayed below it. In this way, you can invite guests only.
  3. Alternatively, use the Add manually section below to add existing workspace contacts or invite new guests personally via email. Type in an email and press Enter, or use the Choose from list option to select an existing contact. If necessary, change the Invitation language. You can add several emails and then click Send invitation.
Guests and users will be added to the room as Content creators who can create and edit documents. New guests will be added to your Guests list.
All available options for inviting users to rooms are listed here.
