Editing rooms
To control each step of collaboration, administrators in ONLYOFFICE DocSpace can perform various operations with the existing rooms: sort and filter the room list to easily find the necessary room, pin some important rooms to the top of the list, move old rooms to the archive, edit the room info, add new members, resend invitations, change the active user permission levels or remove users from the room.
As for managing rooms in DocSpace, the available actions differ depending on the user type:
Section\User typeOwnerDocSpace adminRoom adminUserGuest
My documents
Creating, uploading, moving, copying, renaming, downloading, deleting files and folders
Rooms
Viewing all rooms
Viewing own rooms
Viewing rooms the user is invited to
Creating and editing rooms
Pinning rooms to top
Viewing room info (contacts, history, details)
Inviting external users (guests) to a room
Inviting internal users to a room
Assigning permission levels of own room members
Changing permission levels of own room members
Removing users from own room
Archiving own rooms
Creating a copy of own room
Creating a copy of someone else's room
Editing someone else's rooms: inviting users, assigning and changing permission levels of the room members, removing users from the room
Viewing links of someone else's public room
Changing the owner of someone else's room
Archiving someone else's room
Archive
Viewing all archived rooms
Viewing own archived rooms
Viewing archived rooms the user is invited to
Editing archived rooms
Pinning archived rooms to top
Viewing archived room info (contacts, history, details)
Inviting users to an archived room, assigning and changing permission levels of members
Restoring, copying, or removing someone else's archived rooms
Restoring, copying, or removing own archived rooms
Operations in the room list
Using tools on the top toolbar, you can perform the following operations:
  • Search for a room name using the search bar at the top of the room list.
  • Filter rooms by member or owner, type (Public room, Form filling room, Collaboration, Virtual Data Room, Custom), the existing tags, third-party resources using the Filter icon button. Select the necessary filter parameters and click Apply. To clear the filter, use the Clear icon icon in the upper right corner.
    Filter Filter
  • Sort rooms by parameters (Name, Type, Tags, Owner, Last activity date, Storage) using the Sort icon button. Click the arrow next to the selected parameter to change the sort order.
  • Switch between the available display modes (Thumbnails or Compact) using the Display mode icon or Display mode icon button.
  • Use the Settings icon icon to display or hide the Type, Tags, Owner, Last activity, Storage / Quota columns in the room list (Compact view).
  • Add a tag quickly by clicking the + icon on a room card. Type the tag name in the input field that appears and press Enter to apply. To remove or rename an existing tag, click it directly on the card — the tag becomes editable so you can update its name, or press Delete to remove it.
    Quick tag add Quick tag add
Using the top panel that appears when one or several rooms are selected in the list, you can perform the following operations:
  • Select rooms by type (All, Public, Form filling room, Virtual Data Room, Custom, Collaboration) using the Arrow icon icon.
    Select rooms by type Select rooms by type
  • Pin/unpin the selected room(s) to top.
  • Move the selected room(s) to the archive.
  • Change a quota per room.
  • Disable the quota.
  • View info about the single selected room using the Info icon icon.
    View info View info
  • Delete the room.
Using the right-click menu or the Options icon icon next to the room name, you can perform the following actions:
  • Select icon Select – to select the room in the list. When the room is selected, you can Pin/Unpin it or move to archive using the top toolbar options or view info using the Info icon icon.
  • Open icon Open – to open the room.
  • Pin to top icon Pin to top – to display the room on the top of the list. You can unpin the pinned room clicking the Pin to top icon icon or using the Unpin option in the menu.
  • Disable notifications icon Disable notifications – to disable notifications for this room. You can re-enable notifications using the Pin to top icon Enable notifications option in the menu.
  • Edit room icon Edit room – to rename the room, add tags or an image, change the room owner.
  • Invite contacts icon Invite contacts – to send invitations to users or guests.
  • Copy shared link icon Copy shared link – to copy a link to the Public, Form filling, or Custom room. The contents of the Public or Custom room accessed via this link will be available for viewing without authorization. For a Form filling room, you can copy the link to fill out.
  • More options:
    • Save as template icon Save as template - to save the selected room as a template. You will be able to quickly create new rooms on the base of existing templates.
    • Duplicate icon Duplicate – to duplicate the room.
    • Download icon Download – to download the room.
    • Info icon Room info – to view the following information: Contacts (Administration, Users, Expected users), History (Recent activities), Details (Owner, Type, Content, Date modified, Last modified by, Creation date, Tags, Storage / Quota).
      The Contacts screen also allows you to add new members, resend invitations, change the active user permission levels or remove a user from the room.
    • Embed icon Embed – to embed the room available via a public link.
    • Change the Room Owner icon Change the Room Owner – to change the room owner.
  • Leave the room icon Leave the room – to leave the room. If you are the room owner, you will need to assign another owner first.
  • Move to archive icon Move to archive – to archive the room. Archived rooms can be restored or deleted.
  • Delete room icon Delete room – to permanently delete the room. In the warning window that appears, check the I understand the consequences and want to delete the room box and click the Delete permanently button.
In compact view, using the right-click menu in the Storage / Quota column next to the room name, you can perform the following actions:
  • Change quota (if the default quota is enabled) – to set a custom quota per room.
  • Set to default (if the default quota is enabled and changed) – to set a custom quota to the default value.
  • Disable quota (if the default quota is enabled) – to disable the quota.
When a room quota is set and the limit has been exceeded, a notification banner appears in the room header to alert the room administrator.
Operations within the room
When you open a room by clicking its name in the list, you can use the top toolbar to perform the following actions:
  • Return to the room list using the Return icon arrow.
  • Create new documents, spreadsheets, presentations, PDF forms, folders using the Plus icon Plus icon. In a form filling room, you can create a new PDF form directly in the room, upload a PDF form from DocSpace or from your device, or choose from templates.
  • Manage the room using the Options icon icon:
    • More options:
      • Export room index icon Export room index – to export the index for the Virtual Data Room. The xlsx file with a summary report on the file structure of the room will be exported to the 'My documents' section.
  • Share the public room or form filling room using the Share room button.
  • View info about the room using the Info icon icon.
Manage the room Manage the room
Various operations with rooms
Creating room templates
Room templates allow you to quickly create new rooms with similar settings and content. It's possible to use your own templates or the ones shared with you by other administrators.
  1. Use the right-click menu or the Options icon icon next to the room name in the room list and select the Manage icon Manage -> Save as template icon Save as template option. You can also open the room and use the Manage -> Save as template option in the Options icon menu within the selected room.
  2. Change the Template name if necessary.
  3. Add Room tags. Tags will apply to the room that will be created based on this template.
  4. To share the template with other administrators, click the Access settings link in the Access to template section.
    Turn on the Template available to everyone switch. In this case, all DocSpace and Room admins will be able to create rooms using this template.
    In the Add Users or Groups section, you can choose certain administrators from the list manually. If you select a group, access will be granted only to administrators who are members of this group.
  5. The Open created template option is selected by default.
  6. Click the Create template button.
Creating room templates Creating room templates
In the created template, you can change the template settings, add new files, and edit existing documents.
In a public or custom room, you can create several links with different parameters. The contents of the room accessed via these links will be available for viewing without authorization. For public rooms, the shared link is enabled by default. If you want to get a link for a custom room, you should create a shared link first.
For a form filling room, the link to fill out is enabled by default. This room is available to anyone with the link. External users will have Form Filler permission for all the files.
To create or edit external links:
  1. In the room menu, use the Info icon Info item.
  2. Switch to the Contacts screen.
  3. For a public room, proceed to the next step. For a custom room, use the Create new link option in the Shared links section.
  4. Click the Options icon icon next to the Shared link.
  5. Choose the Link settings option.
  6. If necessary, change the Role for link in a public or custom room (Viewer, Editor, Reviewer, or Commentator).
  7. Change the link name to distinguish various links.
  8. Set a password to protect the link.
    1. Turn on the Password access switcher.
    2. Click the Generate password icon icon to generate a password or enter it manually into the corresponding field.
      The password must be at least 8 characters long. The following characters are allowed: a-z, A-Z, 0-9, !"#%&'()*+,-./:;<=>?@[]^_`{|}
    3. To clean the password field, click the Clean button.
    4. To copy the password to your clipboard for future sharing, click the Copy password button.
      Edit link Edit link
  9. Enable the Restrict file content copy, file download and printing switcher to disable downloads of files and folders from the public or custom room shared via a link.
  10. Use the Invite via link restriction settings to limit what users who join the room via this link can do. You can restrict downloading, copying content, and printing for invited users, independently of the general link settings.
  11. To save the changes made to the shared link parameters, click the Save button.
If you need more than one link for a public or custom room, use the Add link icon Add new link icon in the Shared links section. When creating an additional link, you can:
  1. Set the link name.
  2. Set a password protection as described above.
  3. Restrict file content copy, file download and printing.
  4. Limit availability period for this link by setting an expiration date. Choose the date and time using the date picker.
  5. Save the link by clicking Create.
    Add link Add link
The room will be available to anyone with the link. External users will have View Only permission for all the files in a public or custom room and Form Filler permission in a form filling room.
In a public or custom room, you can change the default Viewer link by selecting a different permission level: Editor, Reviewer, or Commentator. To do that:
  3. Click the View icon icon next to the Shared link.
  4. Choose the necessary option: Editor, Reviewer, Commentator, Viewer.
    Edit link Edit link
    The link for the selected permission level will be copied to the clipboard.
Embedding rooms
You can embed a public, form filling, or custom room available via a shared link to your website so that the room will be accessible to anyone without authorization.
Read the instructions.
If you want to embed the whole DocSpace into your application or find more embedding options to customize them manually (for example, select interface elements to display or embed a room of a different type), please use the DocSpace Settings -> Developer Tools -> JavaScript SDK sections.
Working with form filling rooms
You can upload PDF forms into the form filling room, invite users to fill out a PDF form, review completed forms and analyze data automatically collected in a spreadsheet.
Working with Virtual Data rooms
You can use new capabilities for working with data in a Virtual Data room: indexing of data with the ability to change the index and generate a summary report on the file structure of the room, setting the lifetime of files, prohibition on copying and downloading files, setting watermarks.
