Articles with the tag:
Close
Close
Help Center
Control Panel
Tracking login history
Control Panelv.2.9 ONLYOFFICE Control Panel changelog
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
The Login History section of the Control Panel is used to monitor the latest user login activity including successful logins and failed attempts with an indication of reasons.
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Viewing login history
Switch to the Control Panel within the necessary portal and open the Login History page in the PORTAL SETTINGS section on the left sidebar.
This page displays only the last 20 records. Each record shows which action took place, who performed it and when the event occurred. You can also set the period to store the data. By default, it is set to 180 days.
Tracking login history Tracking login history
To view the detailed statistics for the latest half year click the Download and open report button. The report will open in an .xlsx spreadsheet (LoginHistory_ReportStartDate-EndDate.xlsx).
The file will also be automatically saved to the My documents section.
The login history report includes the following details: user IP address, Browser and Platform which were being used when the registered event occurred, Date and time of the event, name of the User who made an attempt to log in/log out, portal Page where the action has been performed, specific Action (for example, Login Fail. Associated Social Account Not Found).
The records are sorted chronologically in descending order, but you can easily sort and filter the data by any parameter or use the search tool to quickly find a specific record.
In the Online Users section, you can also view the list of the users who are currently logged in as well as each online user session duration.
Docker, Windows and Linux
You Might Also Like This:
Close
