Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Help Center
Control Panel
Switching to HTTPS using Control Panel
Version 3.5.2
Release date: 02/29/2024
General
  • Edited sources build.
Version 3.5
Release date: 03/14/2023
General
Version 3.1.1
Release date: 08/08/2022
General
Version 3.1
Release date: 05/25/2022
General
  • Fixed bugs.
Version 3.0
Release date: 06/07/2021
Update
Search
LoginHistory and AuditTrail
  • New empty screens added.
Restore
SSO
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
Control Panel offers you the possibility to quickly and easily switch your portal to the secure HTTPS protocol.
This option is not currently available in the installation for Windows.
There are two ways to enable HTTPS for your portal via the Control Panel interface:
  • If you don't have any SSL certificates, you can generate a new signed certificate with one click. The Control Panel uses the letsencrypt.org service to generate the CA-signed certificates.
  • If you have an existing private key generated on your server and a public key certificate created on its base (self-signed or issued by a Certification Authority), you can simply upload them in the Control Panel.
View the information about self-signed and CA-signed certificates
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Generate a new certificate
Port 80 must be open in order to successfully generate letsencrypt certificates.
To generate a new certificate:
HTTPS page HTTPS page
  1. Open the HTTPS page in the COMMON SETTINGS section on the left sidebar.
  2. Click the GENERATE AND APPLY button. A popup message box will appear informing you that the certificate and private key are successfully generated.
  3. After that your Control Panel and portal will be restarted and become unavailable during this process. It can take up to 5 minutes. Once the certificate installation process is over, your portal will be available over HTTPS.
To remove the installed certificate, use the DELETE button.
Upload an existing certificate and private key
To use an existing .crt certificate and private .key key:
  2. Click the Plus button next to the CRT certificate field and select your .crt certificate to upload it.
  3. Click the Plus button next to the HTTPS key field and select your private .key key to upload it.
    Before uploading, please make sure that the private key is not encrypted. If you have a password-protected .key file, you will need to decrypt it first.
  4. Once the .crt and .key files are uploaded, click the APPLY button at the bottom of the page.
  5. After that your Control Panel and portal will be restarted and become unavailable during this process. It can take up to 5 minutes. Once the certificate installation process is over, your portal will be available over HTTPS. The domain name that your certificate was issued for is now displayed in the Generated on domain section of the HTTPS page in the Control Panel.
    CA-signed certificate CA-signed certificate
Docker, Windows and Linux
You Might Also Like This:
Close
