Articles with the tag:
Close
Close
Help Center
Control Panel
Updating ONLYOFFICE Workspace to the latest version
Control Panelv.2.9 Control Panel changelog
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Control Panel provides you the possibility to access the most recent versions of each online office component and easily update them.
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Before you start the update process, it is recommended to create your portal data backup to prevent the probability of data loss.
Bare Bones Instructions
  1. In the Control Panel, open the Update page in the COMMON SETTINGS section on the left sidebar. On this page, you can see the list of all the ONLYOFFICE Workspace components with the indication of their statuses (Installed), as well as Current and the latest Available versions.
    Once a new version of a certain module becomes available for downloading and installing, the DOWNLOAD button next to it will appear.
    In case updates are available for several components, including Control Panel, it is important to update Control Panel first of all.
    Update page Update page
  2. Click the DOWNLOAD button. When the downloading process is over, the UPDATE button will appear.
    If you are using the version for Windows, the installation file will be downloaded and stored to your Downloads folder used by default. To update your ONLYOFFICE Workspace Windows version, you will need to launch the installer for each component manually.
  3. Click the UPDATE button. The warning window will open. Click the OK button to start the new version installation process or CANCEL to be able to create a backup first.
  4. After you click the OK button, your Control Panel and portal will be restarted and become unavailable during this process. It can take up to 5 minutes. Once the installation is complete, the updated component Current and Available versions will be the same on the Update page. You can scroll up, click the GO TO PORTAL button and explore new features of the updated module.
If you have previously switched your ONLYOFFICE Workspace Windows version to HTTPS, then you will need to manually bind your security certificate to your portal in the IIS Manager after updating the portal. The instructions on how to do that can be found in the Switching Community Server version 8.5 and later to HTTPS manually section.
You Might Also Like This:
Close
