To make it easy to view a large amount of information, you can hide some rows or columns and display them again.
Hide rows and columns
To hide a row/column,
select a single row/column by double-tapping its heading.
Note: if you want to hide several rows/columns at once, expand the selection dragging the green selection handles .
tap the Hide option in the pop-up menu that appears.
Show rows and columns
To display hidden rows or columns, select visible rows above and below the hidden rows or visible columns to the left and to the right of the hidden columns. Tap the Show option in the pop-up menu that appears.
ONLYOFFICE Help Center uses cookies so that we can provide you with the best user experience. By continuing to use this website you agree that we can store cookies in your browser.
