Статьи с тэгом :
Закрыть
История изменений
Закрыть
Попробовать в облаке
Connecting Dropbox to ONLYOFFICE DocSpace
Connect the Dropbox service to use the connected cloud storage as a third-party resource when creating backups.
Creating authorization keys
In the cloud version, the authorization keys parameters for Dropbox are set up automatically.
To store your DocSpace data backup in Dropbox,
  1. Go to the 'Backup' section (DocSpace Settings -> Backup -> Third-party resource).
  2. Select Dropbox as the desired storage and click the 'Connect' button.
  3. Choose your account, grant the access to ONLYOFFICE application and click 'Create copy'.
Закрыть
