Insert formulas
To perform any calculations you can insert a needed formula manually using the common mathematical operators or insert a predefined formula - Function.
Note: formula language can be set in the application settings.
To insert a function,
  1. select a cell you wish to insert a function into,
  2. open the formula insertion panel by
    • tapping the Insert function icon Insert Function icon before the formula bar on the top, or
    • tapping the Insert object icon at the top toolbar and switching to the Insert formula Function tab,
  3. select one of the commonly used functions (SUM, MIN, MAX, COUNT) or choose the necessary Category in the Categories section and select the function you need,
    Note: to view the function description, tap the Info icon icon.
  4. enter the function arguments either using the on-screen keyboard or dragging to select a range of cells to be included as an argument. If the function requires several arguments, they must be separated by commas.
    Note: generally, numeric values, logical values (TRUE, FALSE), text values (must be quoted), cell references, cell range references and other functions can be used as function arguments.
  5. press the Enter key on the on-screen keyboard.
Insert formulas
