Create or delete sheets
By default a newly created spreadsheet has a single sheet. To add a new one, tap the Add sheet Plus icon located to the left of the sheet navigation panel below the current worksheet.
To delete an unnecessary sheet, touch the sheet tab and hold until the pop-up menu with the Delete option appears, then tap it. Confirm the deletion by pressing ОК.
Pop-up menu
Power up your iOS
