Apply cell style
You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Cell option in the pop-up menu,
  3. swipe up to see the CELL STYLES palette and tap the style you want to apply.
    Cell styles palette
Power up your iOS
